Exposés acceptés
  • Katharina Boudgoust.
  • Towards Classical Hardness of Module-LWE: the linear rank case
  • Xavier Bonnetain, Akinori Hosoyamada, María Naya-Plasencia, Yu Sasaki and André Schrottenloher.
  • Quantum Attacks without Superposition Queries: the Offline Simon’s Algorithm.
  • Jean Kieffer.
  • Calcul d’isogénies à partir d’équations modulaires en genre 2.
  • Gabrielle De Micheli, Rémi Piau and Cécile Pierrot.
  • Discrete logarithm algorithms in pairing-relevant finite fields.
  • Rémi Clarisse.
  • Efficacité globale des protocoles à base de couplage.
  • Chloé Hébant, Duong-Hieu Phan and David Pointcheval.
  • Linearly-Homomorphic Signatures and Scalable Mix-Nets.
  • Magali Bardet, Pierre Briaud, Maxime Bros, Philippe Gaborit, Vincent Neiger, Olivier Ruatta and Jean-Pierre Tillich.
  • An Algebraic Attack on Rank Metric Code-Based Cryptosystems.
  • Antonio Florez Gutierrez.
  • Improving the key recovery in linear cryptanalysis: An application to PRESENT.
  • Alain Couvreur and Isabella Panaccione.
  • The Power Error Locating Pairs algorithm.
  • Olivier Blazy, Laura Brouilhet, Céline Chevalier and Neals Fournaise.
  • Round-Optimal Constant-Size Blind Signatures.
  • Julien Lavauzelle and Julian Renner.
  • Cryptanalyse d’une variante du schéma de McEliece.
  • Matthieu Lequesne and Alain Couvreur.
  • On the security of subspace subcodes of Reed-Solomon codes for public key encryption.
  • Anca Nitulescu, Dario Fiore and David Pointcheval.
  • Boosting Verifiable Computation on Encrypted Data.
  • Martin R. Albrecht, Shi Bai, Pierre-Alain Fouque, Paul Kirchner, Damien Stehlé and Weiqiang Wen.
  • Faster Enumeration-based Lattice Reduction: Root Hermite Factor k^(1/(2k)) in Time k^(k/8 + o(k)).
  • Aude Le Gluher, Pierre-Jean Spaenlehauer and Emmanuel Thomé.
  • Complexité asymptotique fine du crible algébrique.
  • Xavier Bonnetain, Rémi Bricout, André Schrottenloher and Yixin Shen.
  • Better Quantum Algorithms for Subset-Sums.
  • Baptiste Lambin.
  • Linearly equivalent S-boxes and the Division Property.
  • Florian Caullery and Marc Manzano.
  • Exploring Parallelization Strategies for SPHINCS+.
  • Andrea Lesavourey, Thomas Plantard and Willy Susilo.
  • Retrieving short generators of principal ideals in real Kummer extensions.
  • Simon Abelard.
  • Un algorithme (plus) rapide pour calculer des espaces de Riemann-Roch.
  • Loïc Masure, Cécile Dumas and Emmanuel Prouff.
  • Vers une meilleure compréhension de l’apprentissage profond appliqué aux attaques par observation.
  • Patrick Derbez, Pierre-Alain Fouque, Baptiste Lambin and Victor Mollimard.
  • Efficient Search for Optimal Diffusion Layers of Generalized Feistel Networks.
  • Nicolas Bordes and Pierre Karpman.
  • High-order private multiplication in characteristic two revisited.
  • Jade Nardi.
  • Explicit construction and parameters of projective toric codes.
  • Manon Bertin, Ayoub Otmani, Magali Bardet and Couvreur Alain.
  • Understanding the complexity of an algebraic attack on the superdetermined DAGS system.
  • Youssef El Housni and Aurore Guillevic.
  • Optimized and secure pairing-friendly elliptic curve suitable for one layer proof composition.
  • Simon Masson.
  • Verifiable Delay Functions from Supersingular Isogenies and Pairings.
  • Ilaria Zappatore, Eleonora Guerrini and Romain Lebreton.
  • Enhancing simultaneous rational function reconstruction with errors: adaptive error correction capability and new bounds for applications.
  • Andy Russon.
  • The quest for an exception-free windowing elliptic curve scalar multiplication.
  • Paul Huynh.
  • Feistel case: when the boomerang comes back.
  • Florette Martinez and Gilles Zémor.
  • QMDS codes with minimal length.
  • Sarah Bordage and Daniel Augot.
  • Interactive Oracle Proof of Proximity for Products of Reed-Solomon Codes.
  • Guillaume Kaim.
  • Lattice-based (partially) blind signature without restart – Signature (partiellement) aveugle sans abandon, fondee sur les reseaux euclidiens.
  • Lucas Barthelemy.
  • Toward an Asymmetric White-Box Proposal.
  • Adel Hamdi.
  • Blind Functional Encryption.
  • Charbel Saliba, Laura Luzzi and Cong Ling.
  • Key exchange based on Ring-LWE using Barnes-Wall lattices.
  • Abbass Madi.
  • A secure approach for Neural Networks usingHomomorphic Encryption and Verifiable Computation.
  • Arthur Lavice.
  • Multiplication over extension fields for Pairing-based Cryptography: an Hardware Point of view.
  • Amaury Durand.
  • Codes duaux des codes de Reed-Solomon lin ́earis ́es dans le cadre differentiel.
  • Olivier Bernard.
  • Twisted PHS: Using the product formula to solve Approx-SVP in Ideal Lattices.
  • Céline Duguet.
  • Zero-knowledge proofs of MLS.
